Autor Tema: Removiendo Office 2000 Premiun SIN el CD  (Leído 4031 veces)
Desconectado EliteAgent
« : febrero 28, 2006, 07:53:31 am »
He perdido el cd de Office 2000 Premiun y deseo removerlo, cada vez que trato de removerlo me pide el CD.
http://office.microsoft.com/en-gb/assistance/HA011363151033.aspx
http://support.microsoft.com/?kbid=239938
You need to get the program called eraser2k.exe, you can get it here -
http://download.microsoft.com/download/office2000pro/Update/3.1/WIN98Me/EN-US/eraser2k.exe
When you run that file, it will extract the utility.  You then need to run the Eraser2000.exe file and it should do the rest.
You can if you wish manually run this utility with more control by running the Offcln9.exe file also included with this utility with the following switches
Switch       Description         Example
   /a        Aggressive mode.    Offcln9.exe /a
   /L        Create Log file.    Offcln9.exe /Lofflog.txt
   /L!       Log only. Do not    Offcln9.exe /L!offlog.txt
             delete anything.
   /q        Quiet mode.         Offcln9.exe /q
   /r        Restart system.     Offcln9.exe /a /q /r
   /s        Safe mode.          Offcln9.exe /s
So to do a secure and total removal logged and without prompt and self reboot, type at a command prompt :-
Offcln9.exe /a /Lremoved.txt /q /r
and your computer will never know office had ever been installed.
You may have to re-install some programs that use any of the office shared program files like "ACT!" or "SQL", but as you are going to re-install ofice anyway, that doesn't matter too much in your case.
One other note... this tool, according to microsoft, hasn't been tested with Windows XP, and to be used at your own discression under that operating system.
hope that helps! :)
 [size=10
