Autor Tema: aplicacion para bloquear llamadas entrantes?  (Leído 2233 veces)
Desconectado LicH
    • Sv Community
« : octubre 11, 2012, 01:35:36 pm »
existe algo en la store de BB, que permita bloquear las llamadas, asigandolas a alguna lista o algo similar?
es un favor que le hago a un compañero que por motivos de delincuencia quiere bloquear llamadas entrantes y no puede cambiar su numero.
alguien sabe?
Desconectado Maitro...
Re:aplicacion para bloquear llamadas entrantes?
« Respuesta #1 : octubre 11, 2012, 04:19:04 pm »
Sencilla, pero funcional ;)
Blockem - Call Blocking
http://appworld.blackberry.com/webstore/content/46754/?lang=en
Note:  Permission must be set to ALLOW in the Options-Applications for OS5 or Options-Devices-Application Management for OS6 for Block'em
Block'em will block any phone number, block callers with private or unknown caller id.  Block'em has Pickup and Hangup feature which do not allow the caller to leave a voice mail.
You can also select the phone number to block from the CallLog, Messages and AddressBook applications.
With the Advanced Blocking feature enabled your BlackBerry will not make any sounds when the caller is blocked.
Block'em does not block text messages.
Features
* Block any phone number
* Block unknown or private callers
* With Advanced Blocking enabled your BlackBerry will not make any sounds
* Block wildcard. eg: 1800*  will block all calls starting with 1800
* Pickup and Hangup.  Do not allow caller to leave you a voice mail
* Quick block marketing callers: eg: 1800, 1866, 1877 and 1888 callers
* Match last digits in the number.   This feature is useful for International users where you can tell Block'em to match on the last 3-10 digits in the phone number
* Adjust the blocking and hangup delay time for better results
* Integrate with CallLog, Messages and AddressBook apps.  Block caller directly in these apps (Due to a bug on some of the BBOS you can not block from the CallLog, the work around is to use the Messages app or log all calls in Block'em and block from there)
* Enable Do Not Disturb for specific period from 30mins to 8 hours.  Only caller with type ALLOW will be able to call you when DND is enabled
* Save all incoming calls to the logfile.
* Export and Import filters for backup or when you upgrade OS
* Easy to configure and to use
« Última Modificación: octubre 11, 2012, 04:24:19 pm por Maitro... »
Desconectado LicH
    • Sv Community
« Respuesta #2 : octubre 11, 2012, 05:36:05 pm »
le dire que la instale aunque en los comments los usuarios dicen que no funciona. pero gracia maitro.! :)
« Respuesta #3 : octubre 11, 2012, 09:44:10 pm »
Al menos en mi 9800 funciona bien :)
Me imagino que es por falta de permisos que no les aha funcionado a los que han puesto los malos comentarios x_x
