The Pencil Project's unique mission is to build a free and opensource tool for making diagrams and GUI prototyping that everyone can use.
Top features:
Built-in stencils for diagraming and prototyping
Multi-page document with background page
Inter-page linkings!
On-screen text editing with rich-text supports
Exporting to HTML, PNG, Openoffice.org document, Word document and PDF.
Undo/redo supports
Installing user-defined stencils and templates
Standard drawing operations: aligning, z-ordering, scaling, rotating...
Cross-platforms
Adding external objects
Personal Collection
Clipart Browser
Object snapping
Sketchy Stencil
And much more...
Licensing and Versions:
Pencil will always be free as it is released under the GPL version 2 and is available for virtually all platforms that Firefox 3 can run. The first version of Pencil is tested against GNU/Linux 2.6 (Fedora, Ubuntu and Arch) with GTK+, Windows XP and Windows Vista/7.
Fuente:
http://pencil.evolus.vn/en-US/Home.aspx
Ejemplos de lo que se puede hacer:
Acá pueden ver mas screenshots:
http://pencil.evolus.vn/en-US/ScreenShots.aspx
Download Addon:
http://evoluspencil.googlecode.com/files/Pencil-1.2-0-fx.xpi
Pero además este addon se puede instalar en forma de aplicación:
http://pencil.evolus.vn/en-US/Downloads/Application.aspx
Lastimosamente este addon es compatible con versiones inferiores de FF3.6, por lo que aca les dejo una guía de como hacerlo funcionar en FF4:
1. Download the Pencil-1.2-0-fx.xpi
2. Unzip it with your favorite zip archiver
3. Open install.rdf
4. Locate the string - em:maxVersion="3.6.*"
5. Replace it with - em:maxVersion="4.*"
6. Save the file. Now your file should look something as shown in below screenshot
7. Now archive all the files - install.rdf, update.rdf & chrome.manifest - and the directory - chrome - into one zip file and name it as Pencil-1.2-0-fx.xpi. It does not necessarily has to be Pencil-1.2-0-fx.xpi, you can have it as MyFile.zip or anything of your choice.
8. Now open up Firefox 4, go to Tools menu and select Add-ons
9. Click Install Add-on From File...
10. Select the archive you just created and you are done
Fuente:
http://jaykhimani.blogspot.com/2011/04/installing-evolus-pencil-extention-on.html
