Hey compa talvez te sirve este ...
Active File Recovery Pro v7.1 build 901
Active@ File Recovery is a powerful software utility, designed to restore accidentally files and directories, that have been lost or deleted from your Windows system. It allows you to recover files that have been deleted from the Recycle Bin, as well as those deleted after avoiding the Recycle Bin (e.g. Shift-Delete) and allows you to recover data after formatting or loss of partitions. Active@ File Recovery will also undelete files that have been lost by
damage, virus or directory destruction. The utility scans computer hard drives in minutes and displays all files which can be recovered.
Active@ File Recovery can be installed on and run from a floppy disk, so that the risk of overwriting your data is minimized.
Active@ File Recovery will help you to restore data residing on hard drives or floppy drives formatted in any of the following file systems:
• FAT12
• FAT16
• FAT32
• NTFS
• NTFS5
It works under all Windows family operating systems:
• Windows 95
• Windows 98
• Windows ME
• Windows NT
• Windows 2000
• Windows XP
• Windows Server 2003
Active@ File Recovery supports:
• IDE, ATA, SCSI hard drives and floppy disks
• Damaged or deleted RAID virtual reconstruction (RAID-0, RAID-1, RAID-5, Span)
• Large-sized drives (more than 128 GB)
• Long file names and local language (non-English) file names
• Recovery of compressed, fragmented and encrypted files on NTFS
• Detection and recovery from deleted or damaged file partitions
• Saving scan results to the storage and opening them later on
• Deleted files filtering, exact or partial file name search
• Disk Image creation and restoring (restores from a backup file that represents a drive)
Download:
CODE
http://rapidshare.com/files/28502854/Active_File_Recovery_.rar
Password: www.2baksa.net
