Autor Tema: Nokia PC Suite 6.8 Release 22  (Leído 1848 veces)
Desconectado Snipe
« : mayo 27, 2006, 04:59:58 pm »
Nokia PC Suite is a package of güindous-based PC applications developed especially for use with Nokia phones.
Depending on your phone model, Nokia PC Suite lets you edit, synchronize and back up many of your phone's files on a compatible PC through a cable or wireless connection.
Here are some key features of "Nokia PC Suite":
· Back up and restore phone files
· Transfer information, pictures, and music from phone to phone or phone to PC
· Synchronize your phone and PC calendars
· Edit contacts, pictures, and phone file names
· Install Java™-based applications in your phone
· Convert ringing tone formats
· Play multimedia messages and videos
· Send text messages from the PC
· Connect by using your phone as a modem
Connection method compatible with your Nokia mobile phone:
- Infrared (IrDA) port
- Bluetooth via a supported stack: Digianswer Bluetooth Software Suite, - micro$oft güindous XP Bluetooth, or WIDCOMM Bluetooth for güindous 1.4
- Nokia Connectivity Cable DKU-2 (USB) or Nokia Connectivity Adapter Cable DKU-5 (serial)
Ex freevvare, gente!
http://nds2.nokia.com/files/support/global/phones/software/Nokia_PC_Suite_68_rel_22_spa_web.msi
guía de uxuario:
http://nds2.nokia.com/files/support/global/phones/software/Nokia_PC_Suite_68_UG_spa.pdf
« Última Modificación: mayo 27, 2006, 05:01:57 pm por Snipe »
Desconectado antonio
Re: Nokia PC Suite 6.8 Release 22
« Respuesta #1 : febrero 24, 2007, 07:33:49 pm »
fijate que esta mal todavia ese pc suite hay que parcharlo para que te funcione con varios telefonos es mejor el anterior 6.70.22
