Autor Tema: Skype para Windows Mobile  (Leído 4815 veces)
Desconectado obser7er
  • ferg(at)pcpimpz.com
« : julio 31, 2010, 12:00:34 am »
Probado y funcionando con WinMo 6.1 :thumbsup: :thumbsup:
Skype for Pocket PC is free and simple software that enables you to make free calls anywhere in the world with your handheld. Created by the people who brought you Kazaa, Skype uses innovative P2P (peer-to-peer) technology to connect you with other users. It is quick and easy to install and offers several features, including SkypeOut calling from Skype to regular and mobile phones worldwide, free conference calling, and secure file transfer. Skype calls have better sound quality than your regular phone and are highly secure with end-to-end encryption.
System requirements:
Operating systems Windows Mobile 6.x, Windows Mobile 5.x, Windows Mobile
Additional requirements Compatible devices: Pocket PC, Classic or Professional; Smartphone and standard devices. A minimum 12MB of free storage memory on your device or 6MB if you are installing from a memory card. Data usage costs apply for using Skype over 3G mobile networks (EDGE, EV-DO and UMTS)--an unlimited data plan is recommended. WiFi connection or 3G/2G data connection (Skype cannot guarantee voice quality over 3G/2G. You may also be liable to additional data charges so please check with your operator before using). Use a headset for the best sound quality on calls.
License model Free
A la descarga:
http://download.cnet.com/Skype-for-Windows-Mobile/3000-2349_4-11042931.html
info: ferg(at)pcpimpz.com
Desconectado LicH
    • Sv Community
Re:Skype para Windows Mobile
« Respuesta #1 : julio 31, 2010, 08:33:34 am »
no se si me equivoque pero skype de ya dias dejo de dar funcionamiento para WM (al menos con sus descargas para este sistema, y termina a finales de este año con el servicio), solo se podra utilizar el proximo año en BB y iphones
aqui dejo la nota
https://support.skype.com/faq/fa10411/Why-can-t-I-download-Skype-Lite-or-Skype-for-Windows-phones;jsessionid=6FCFF6DD8D6E5B70F0B2565B36F847F9
« Última Modificación: julio 31, 2010, 08:35:09 am por LicH »
« Respuesta #2 : julio 31, 2010, 10:12:46 am »
Aunque no tenga soporte el programa sigue funcionando, así como Windows 98 XD este es Skype para WinMo... distinto del Skype lite que menciona que dejara de funcionar.
« Última Modificación: julio 31, 2010, 10:51:01 am por obser7er »
Desconectado LicH
    • Sv Community
« Respuesta #3 : julio 31, 2010, 11:28:12 am »
confirmame si podes hacer llamadas a teléfonos fijos de USA? o sea afuera de la red skype :unsure:
pense que ya no funcionaba
edit: te funciona la cam secundaria para hacer videollamadas?
« Respuesta #4 : julio 31, 2010, 11:42:13 am »
Llamadas EEUU ni idea... XD
La camara secundaria igual, aunque en el N5800XM nunca me fije si funcionaba XD
Desconectado LicH
    • Sv Community
« Respuesta #5 : julio 31, 2010, 11:45:05 am »
según tengo entendido no es un simple messenger con usuarios skype (llamadas y videollamadas), si no que te permite hacer llamadas a fijos, al estilo pc.
bueno buscare mas info.
« Respuesta #6 : julio 31, 2010, 11:48:18 am »
Yo se... cuando entro me sale que no tengo credito... desgraciadamente yo lo tengo que usar de ves en cuando porque ese medio afinamos los detalles de las compras en EEUU, lo malo que siempre dentro de la red Skype. No veo porque no va a funcionar poniendole credito.
Desconectado rmgm81
« Respuesta #7 : julio 31, 2010, 03:32:57 pm »
Skype es sinonimo de m@#$%a, prueba mejor a instalar Fring, la onda es que puedes administrar varias cuentas como Skype, Voipcheap(mi preferida ya que puedes llamar a muchos paises sin costo pero solo a fijos)tambien puedes usarlo con gizmo y es muy facil de configurar.
Saludos.
Desconectado DarkAvenger
« Respuesta #8 : julio 31, 2010, 07:19:20 pm »
Hace un par de semanas Fring ya no soporta Skype, si lo bajas ya no te sale la opcion de utilizar la cuenta de skype.
Yo baje el skype para windows mobile y si funciona igual que con la PC messenger, llamadas a contactos skype, llamadas con skype out, recibir llamadas con skype in, usando 3G o wi fi......funciona nitidisimo
Solo las video llamadas si no las he probado, pero lo demas esta super bien, ya el skype para windows mobile no se puede bajar del sitio de skype pero alli mismo dice, si ya lo bajo, pues sigalo usando.
Gracias por el link de descarga lo guardare en mis backup porque sera articulo de lujo dentro de poco.
Desconectado LicH
    • Sv Community
« Respuesta #9 : agosto 01, 2010, 07:44:27 am »
Gracias por la aclaración
