Gracias, aunque por lo visto un tutorial no es algo que se vea en un futuro proximo
PD: Pues claro, que otra ip te estaría molestando
Ahi te dejo una info de tu IP
Initiating Ping Scan at 15:42
Scanning 190.87.109.202 [5 ports]
Completed Ping Scan at 15:42, 0.05s elapsed (1 total hosts)
Initiating Parallel DNS resolution of 1 host. at 15:42
Completed Parallel DNS resolution of 1 host. at 15:42, 0.01s elapsed
Initiating SYN Stealth Scan at 15:42
Scanning 190.87.109.202 [1000 ports]
Discovered open port 80/tcp on 190.87.109.202
Discovered open port 23/tcp on 190.87.109.202
Completed SYN Stealth Scan at 15:42, 4.65s elapsed (1000 total ports)
Initiating Service scan at 15:42
Scanning 2 services on 190.87.109.202
Completed Service scan at 15:42, 5.06s elapsed (2 services on 1 host)
Initiating OS detection (try #1) against 190.87.109.202
Retrying OS detection (try #2) against 190.87.109.202
Initiating Traceroute at 15:42
190.87.109.202: guessing hop distance at 2
Completed Traceroute at 15:42, 0.06s elapsed
Initiating Parallel DNS resolution of 4 hosts. at 15:42
Completed Parallel DNS resolution of 4 hosts. at 15:42, 0.21s elapsed
SCRIPT ENGINE: Initiating script scanning.
Initiating SCRIPT ENGINE at 15:42
Completed SCRIPT ENGINE at 15:42, 3.59s elapsed
Host 190.87.109.202 appears to be up ... good.
Interesting ports on 190.87.109.202:
Not shown: 998 filtered ports
PORT STATE SERVICE VERSION
23/tcp open telnet Alcatel/Thomson SpeedTouch DSL router admin interface
80/tcp open http Alcatel/Thomson SpeedTouch aDSL http config 1.0
|_ HTML title: HTTP/1.0 401 Authorization Required
| HTTP Auth: HTTP Service requires authentication
| Auth type: Digest, realm = SpeedTouch
|_ Auth type: Basic, realm = SpeedTouch
Warning: OSScan results may be unreliable because we could not find at least 1 open and 1 closed port
Aggressive OS guesses: HP 9100c Digital Sender multifunction printer (96%), Netgear CG814WG v2 wireless cable modem (95%), Thomson TCW710 wireless cable modem (93%), Brother MFC-7820N multifunction printer (92%), Cisco IP Phone 7941 (92%), Cisco IP Phone 7941 or 7961 (92%), Microsoft Windows XP SP2 (91%), EtherWerX PT-1000 PPPoE terminator (90%), NCR 5676 or 5688 automated teller machine (90%), Thomson ST 536i ADSL modem (90%)
No exact OS matches for host (test conditions non-ideal).
Uptime guess: 0.082 days (since Wed Feb 4 13:45:03 2009)
TCP Sequence Prediction: Difficulty=256 (Good luck!)
IP ID Sequence Generation: Incremental
Service Info: Device: broadband router
TRACEROUTE (using port 23/tcp)
HOP RTT ADDRESS
1 7.27 201.247.31.254
2 7.46 10.192.68.138
3 19.86 190.87.109.202
Deberias deshabilitarle al router el puerto 80 y el 23 para que no te friegen desde el internet
