Estamos hablando del MF180!! y el hecho que cree una unidad virtual no tiene nada que ver con la micro, eso lo hace para acceder al software interno
Demostrame que no tiene nada que ver en estos modems (MF100 = referencia)
ZTE MF180 Modem SpecificationsBrand Name: ZTE
Model Number: ZTE MF180
Type: Wireless
Kind: Internal
Transmission Rate: 3.6Mbps
Interface Type: USB
Application: Laptop
hadpa: usb
Place of Origin: China (Mainland)
Specifications
The following table shows the specification of your device.
Interface: Type USB 2.0 HIGH SPEED
System supported: Supports most types of laptop and desktop PC.
Operating systems supported: Windows XP,Vista,Windows 7 MAC10.4, 10.5, 10.6
Functions: SMS service ,Data service, Applications management, support microSD card, etc.
Network Standards: HSDPA/WCDMA/EDGE/GPRS/GSM
Transmission speed(Max): HSDPA:3.6Mbps DL WCDMA PA:384 Kbps UL/DL
Temperature: Storage:-40°C ~+80°C Operation: -10°C ~+60°C
Dimension: 76mmX26mmX11mm(
Weight: About 21g
microSD:
Support up to 32GB microSD card fuente
www.google.com
http://www.aliexpress.com/product-gs/387449535-ZTE-MF180-HSDFA-wholesalers.html
