Encuesta
Con cuál te quedarías ???
Sennheiser HD205+mic
3 (23.1%)
Stanton DJ Pro 60+mic
0 (0%)
Gamecom 367/377
6 (46.2%)
Otro(comentar cuál!)
4 (30.8%)
Total de votos: 12
Autor Tema: Consulta para Audiófilos....  (Leído 6295 veces)
Desconectado obser7er
  • ferg(at)pcpimpz.com
« : enero 18, 2010, 12:35:00 am »
Bien tengo menos de 24horas para decidirme entre las siguientes opciones:
Audifonos más un micrófono aparte(Headphone+mic):
Sennheiser HD205
DJ headphones, rotatable ear cup
Technical Data
Cable length   10 ft. (approx 3 m)
Ear coupling   Semi On-the-ear
Frequency response (headphones)   14 - 20,000 Hz
Jack plug   1/8
Nominal impedance   32 ohms
Sound pressure level (SPL)   112 dB (SPL)
Total harmonic distortion (THD)   < 0.5%
Transducer principle   Dynamic, closed
Weight w/o cable   7.3 oz. (206 g, no packaging)
UPC code   615104102095
EAN code   4044156001791
Dimensions (single)   4.3 x 8.3 x 10.80 inches
Weight (single)   0.80 lbs
http://www.sennheiserusa.com/private_headphones_dj-headphones_500263
Stanton - DJ PRO 60 Stereo Headphones
Adjustable headband for added comfort
40mm drivers for deep bass
8-1/2' cable
80mW maximum power input
1/7" stereo jack with 1/4" adapter
Frequency response: 20Hz - 18kHz
Sensitivity: 102dB
Impedance: 50 ohms
Includes carrying pouch :thumbsup:
http://www.stantondj.com/v2/prod_djpro60.asp
o Audífonos con micrófono integrado(headset):
Plantronics GameCom 367 Closed-Ear o los 377 Open-Ear(para no aislarme del todo de mi entorno)
SPEC
Frequency Response   20Hz–20KHz
Connector   3.5mm
Ear Coupling   Circumaural
Cord Length   6.5 ft.
Weight   1.13 lbs.
Microphone SPEC
Microphone Frequency Response   100Hz-8KHz
Feature
Features   Ear cushion material: Non-Allergenic
Microphone Boom: Concealed
Mute Control
Volume Mute
Closed ear design for complete gaming immersion
http://www.plantronics.com/north_america/en_US/products/computer/pc-gaming-headsets/gamecom-367
Actualmente uso unos Sennheiser pc30 que por el precio y estéticamente no parecería que suenan tan bien... pero tengo en mente cambiarlos por unos que transmitan con más fidelidad las notas musicales y los diversos efectos de sonido de los juegos y películas... o por una solución más práctica, aunque con la calidad de los actuales, más parece que solo son ganas de gastarme el pi$to XD
En fin se escuchan leen sugerencias y comentarios :thumbsup:
« Última Modificación: enero 18, 2010, 12:53:23 am por obser7er »
info: ferg(at)pcpimpz.com
mored
Re:Consulta para Audiófilos....
« Respuesta #1 : enero 18, 2010, 12:47:45 am »
por las especificaciones no mucho pero por estyle me parecen mejor los Plantronics GameCom 367 Closed-Ear combinacion de stylo mas caraceristicas buenas  ohyea:  :thumbsup:
Desconectado Xabre
  • ボン サブレウオルッフ ファビアン
« Respuesta #2 : enero 18, 2010, 01:18:06 pm »
depende para que lo ocupes, pero si solo es para oir musica o juego en private y charlar con las novias en el skype la primera opcion ba sobrada.
Sennheiser HD205
pero ya si es para algo mas profesional donde necesites la total audio ayuda analitica asi como un ciego y su sonar.
la opcion 3 es la ideal pero una cosa, esas orejeras si pesan y te puede doles la nuca y parte de la cabeza por ese peso xtra.
Campolon
« Respuesta #3 : enero 18, 2010, 01:31:38 pm »
Creo que para envolverte mas en las experiencias del juego y de las movies te queda mas el Plantronics.  Las otras 2 no las consideraria yo.
Desconectado LaUt
« Respuesta #4 : enero 18, 2010, 01:52:01 pm »
Sennheiser HD205
Sería bueno saber específicamente como los vas a usar, en lo personal no ocupo micrófono y tengo unos numark igual a los de la imagen, y me han funcionado bien... los compre en RGnieto y me costaron como 11$ hace como 2 años y funcionan de toque todavía.
Campolon
« Respuesta #5 : enero 18, 2010, 02:08:16 pm »
Creo que el amigo quiere comprar un producto de altisima calidad... no creo que le sirvan los numark... esas marcas son para usos mas cotidianos creo yo
Desconectado LaUt
« Respuesta #6 : enero 18, 2010, 02:13:51 pm »
Asi es... por eso la pregunta... por que esos que tengo realmente no me doleria que se arruinaran, aun que han salido buenos...
« Respuesta #7 : enero 18, 2010, 02:28:16 pm »
Exacto, por andar con miserias a veces uno no puede disfrutar sonidos que ni sabías que existían... yo sentí una diferencia considerable de pasar de unos Radioshack(en realidad son unos Plantronics remarcarcados) de gama baja a unos Sennheiser de precio similar, pero muuuuuuuuuuuuchísima mejor fidelidad con los sonidos.
El recomendar unos numark hace a LaUT un NO audiófilo... dudo que transmitan los sonidos con las misma calidad que los Sennheiser que uso actualmente.
Desconectado LaUt
« Respuesta #8 : enero 18, 2010, 02:34:49 pm »
hey gracias por compartirnos que tenes unos "Sennheiser" realmente mis audifonos los ocupo para "oir musica" y no interrumpir a los demas... ahora he sido conforme porque esos pude comprar en ese momento y me han servido hasta la fecha, ahora cada quien compra y usa lo que puede y tiene, simplemente es mi opinion...
P.D. creo que era una encuesta y te tomaste el tiempo de poner la opcion "otros".
esa es mi opinion.
« Última Modificación: enero 18, 2010, 02:38:44 pm por LaUt »
Desconectado JorgeT
« Respuesta #9 : enero 18, 2010, 02:37:03 pm »
Yo compre unos Sennheiser  EH150  y es lo mejor q he tenido en cuanto a audifonos
todavia los podes  encontrar en amazon a  un buen precio
sennheiser altamente recomendado!
Desconectado Pattyxoxo
  • Judge XOXO Dredd
« Respuesta #10 : enero 18, 2010, 07:34:16 pm »
estos son los mios, si te alcanza la cobija dale con todo no te vas a arrepentir XD
http://www.bose.com/controller?url=/shop_online/headphones/noise_cancelling_headphones/quietcomfort_15/index.jsp
« Respuesta #11 : enero 18, 2010, 08:19:51 pm »
No es por nada pero creía que cuando hacías algún comentario era para ayudar para tener un panorama... pero al parecer es pura pretensión XD
Pero sin duda es una excelente opción. Gracias, pero por eso puse productos que no superan los $75.00. Pero si tuviera una cobija de las que vos usas sin duda me compraría QuietComfort3 XD
« Última Modificación: junio 22, 2010, 09:04:29 pm por obser7er »
Desconectado Israfel_JK
« Respuesta #12 : enero 18, 2010, 08:51:48 pm »
Pero sin duda es una excelente opción. Gracias, pero por eso puse productos que no superan los $75.00. Pero si tuviera una cobija de las que vos usas sin duda me compraría QuierComfort3 XD
Veo que los queres con microfono integrado... asumo que son para jugar principalmente... me permito sugerir (ya que veo que traeras cosas de USA) que probes estos modelos:
- Grado SR 60i
http://www.headphone.com/headphones/grado-sr-60i.php
- Sennheiser PX 100 ó Sennheiser PX 100-II
http://www.headphone.com/headphones/sennheiser-px-100.php
http://www.headphone.com/headphones/sennheiser-px-100-ii.php
- Koss Porta Pro ó los mismos Edición 25 Aniversario
http://www.headphone.com/headphones/koss-porta-pro.php
Todos los anteriores con precio por debajo de los $100 USD, calidad garantizada :thumbsup:
Cual elegiria entre todos?! El Grado SR 60i (Opinión personal... ya que el único contra que las personas le encuentran es que el sonido se escapa mucho... pero es necesario que sean "abiertos" para que la calidad de sonido sea la mejor posible)
Un pequeño "consejo" si a alguien le interesa un poco la onda "audiofila" le recomiendo no gastar mas de $100 en un par de audifonos si no se pretende utilizar un amplificador y escuchar canciones en calidad como .flac
Si se quieren para un mp3 no se debe gastar mas... claro, si se puede pero no tendria sentido.
Saludos!
« Última Modificación: enero 18, 2010, 08:53:54 pm por Israfel_JK »
  • Judge XOXO Dredd
« Respuesta #13 : enero 18, 2010, 10:39:11 pm »
mil disculpas si te pareci pretenciosa pero en ningun lugar del post o reply's vi alguna cifra limite o rango de precios a buscar.
« Respuesta #14 : enero 19, 2010, 01:12:01 am »
Perdón entonces, me retracto!
