Autor Tema: Ayuda con PHPMyAdmin  (Leído 6531 veces)
Desconectado *MAURO*
  • El Futbol: la unica religión ke no tiene Ateos ッ
Re: Ayuda con PHPMyAdmin
« Respuesta #15 : septiembre 07, 2007, 11:57:14 am »
te pongo aki lo de mi config.inc.php
<?php
/* $Id: config.sample.inc.php 9689 2006-11-10 20:05:49Z nijel $ */
// vim: expandtab sw=4 ts=4 sts=4:
 * phpMyAdmin sample configuration, you can use it as base for
 * manual configuration. For easier setup you can use scripts/setup.php
 * All directives are explained in Documentation.html and on phpMyAdmin
 * wiki <http://wiki.cihar.com>.
 * This is needed for cookie based authentication to encrypt password in
 * cookie
$cfg['blowfish_secret'] = 'xMAUROx'/* YOU MUST FILL IN THIS FOR COOKIE AUTH! */
 * Servers configuration
$i 0;
 * First server
$i++;
/* Authentication type */
$cfg['Servers'][$i]['auth_type'] = 'cookie';
/* Server parameters */
$cfg['Servers'][$i]['host'] = 'localhost';
$cfg['Servers'][$i]['connect_type'] = 'tcp';
$cfg['Servers'][$i]['compress'] = false;
/* Select mysqli if your server has it */
$cfg['Servers'][$i]['extension'] = 'mysql';
/* User for advanced features */
$cfg['Servers'][$i]['controluser'] = 'root'//USUARIO DE MYSQL
$cfg['Servers'][$i]['controlpass'] = 'm*bla**bla**2'//CONTRASENIA USUARIO DE MYSQL
/* Advanced phpMyAdmin features */
// $cfg['Servers'][$i]['pmadb'] = 'phpmyadmin';
// $cfg['Servers'][$i]['bookmarktable'] = 'pma_bookmark';
// $cfg['Servers'][$i]['relation'] = 'pma_relation';
// $cfg['Servers'][$i]['table_info'] = 'pma_table_info';
// $cfg['Servers'][$i]['table_coords'] = 'pma_table_coords';
// $cfg['Servers'][$i]['pdf_pages'] = 'pma_pdf_pages';
// $cfg['Servers'][$i]['column_info'] = 'pma_column_info';
// $cfg['Servers'][$i]['history'] = 'pma_history';
// $cfg['Servers'][$i]['designer_coords'] = 'pma_designer_coords';
 * End of servers configuration
 * Directories for saving/loading files from server
$cfg['UploadDir'] = '';
$cfg['SaveDir'] = '';
YA LO REVISE COPIE OTRO Q NO ERA XD
HACER LO SIGUIENTE
Dentro del directorio de PhpMyAdmin que se coloca en documentRoot, o sea htdocs …Buscar el archivo config.sample.inc.php y editar el nombre y dejarlo como config.inc.php para cambiar los valores del usuario y password con el que nos conectamos y quitarle el comentario  //
<?php
$cfg
['Servers'][$i]['controluser'] = 'root';
$cfg['Servers'][$i]['controlpass'] = 'irbt2'
Anteriormente estaba
<?php
//$cfg['Servers'][$i]['controluser'] = ' pma';
//$cfg['Servers'][$i]['controlpass'] = ' pmapass';
te pongo un articulo
http://www.desarrolloweb.com/articulos/844.php
« Última Modificación: septiembre 07, 2007, 03:38:43 pm por *MAURO* »
