Autor Tema: Ayuda con compra de microprocesador AMD  (Leído 2740 veces)
Desconectado Midnight
« : mayo 25, 2017, 02:04:14 pm »
Buenas tardes comuniteros vengo este dia a implorar su ayuda  :sur: :sur:
Veran me han regalado un cpu con estas specs:
- MB. ASRock N68C-GS FX
- CPU AMD Semprom(tm) 145 Processor 2.80 GHZ
- HDD 500 Gb
- RAM 8 Gb
- Fuente Unknow (Chinita)  :D
- Tarjeta de video: - Integrated NVIDIA ® GeForce 7025 graphics
                              - DX9.0 VGA, Pixel Shader 3.0
Buscando en la pagina de amd encontre el manual de esta mother y en este manual ésta info del cpu:
Support for Socket AM3+ processors (see CAUTION 1)
- Support for AM3 processors: AMD Phenom TM II X6 / X4 / X3 /
X2 (except 920 / 940) / Athlon II X4 / X3 / X2 / Sempron
processors
- Support for Socket AM2+ / AM2 processors: AMD Phenom TM
FX / Phenom / Athlon 64 FX / Athlon 64 X2 Dual-Core / Athlon
X2 Dual-Core / Athlon 64 / Sempron processor
- Supports 8-Core CPU
- Supports UCC feature (Unlock CPU Core) (see CAUTION 2)
- Supports AMD’s Cool ‘n’ Quiet TM Technology
- FSB 1000 MHz (2.0 GT/s)
- Supports Untied Overclocking Technology (see CAUTION 3)
- Supports Hyper-Transport Technology
CAUTION 1: This motherboard supports CPU up to 95W.
CAUTION 2: UCC (Unlock CPU Core) feature simplifies AMD CPU activation. As long as
a simple switch of the BIOS option “ASrock UCC”, you can unlock the extra
CPU core to enjoy an instant performance boost. When UCC feature is
enabled, the dual-core or triple-core CPU will boost to the quad-core CPU,
and some CPU, including quad-core CPU, can also increase L3 cache size
up to 6MB, which means you can enjoy the upgrade CPU performance with
a better price. Please be noted that UCC feature is supported with AM2+ /
AM3 / AM3+ CPU only, and in addition, not every AM2+ / AM3 / AM3+ CPU can
support this function because some CPU’s hidden core may be
malfunctioned.
CAUTION 3: This motherboard supports Untied Overclocking Technology.
Aca esta la lista de los procesadores soportados http://www.asrock.com/MB/NVIDIA/N68C-GS%20FX/index.es.asp#CPU
Viendo que acepta micros mucho mejores que el que tiene pues quiero saber por cual optar con la limitante de la fuente y que sea B.B.B.
Gracias por su ayuda  :thumbsup: :thumbsup:
Mi plan es vivir eternamente. Hasta ahora lo estoy cumpliendo perfectamente.
Experiencia es el nombre que damos a nuestras equivocaciones.
Re:Ayuda con compra de microprocesador AMD
« Respuesta #1 : mayo 25, 2017, 05:16:03 pm »
Un phenom x4 de 95 watts, es lo mas que podes aspirar. El 955, aunque hay un x6 de 95 watts pero es un pepe raro el 1055T
« Última Modificación: mayo 25, 2017, 05:17:34 pm por Necrolancer »
« Respuesta #2 : mayo 25, 2017, 05:40:08 pm »
lol mi glorioso 1055T, ahi esta todavia volando verga como el primer dia :V
Desconectado delroy
« Respuesta #3 : mayo 25, 2017, 05:41:48 pm »
el FX4300 tambien sale que lo soporta
por ahi alguien lo vendia en los clasificados
Lirius91
« Respuesta #4 : mayo 25, 2017, 07:08:55 pm »
Aca encontré una Lista de procesadores FX  y según que hay varios hexa y octacore compatibles
« Respuesta #5 : mayo 25, 2017, 09:45:51 pm »
Hey y que paso con el Ryzen pues? Que no te lo ibas a dar?
« Respuesta #6 : mayo 26, 2017, 08:27:15 am »
Yo estuve a punto de puchar el botton buy tambien, pero es que si no estas tan urgido de upgrade es mejor esperar a fin de año al menos para planchar todas las issues.
Yo para navidad me lo voy a dar ya con una motherboard con bios pulido y ddr3 de 3400 :)
« Respuesta #7 : mayo 26, 2017, 08:45:42 am »
Gracias ya tengo una idea mas o menos de que comprar  :thumbsup: :thumbsup:
« Respuesta #8 : mayo 26, 2017, 10:57:51 am »
ya esta comprado. ahorita esperando q llegue
« Respuesta #9 : mayo 26, 2017, 11:07:10 am »
Pero ponele hype man, cual compraste? Cuanto de Ram y a que frecuencia? Que mobo?
« Respuesta #10 : mayo 26, 2017, 11:08:21 am »
La RAM nose si sea buena idea esperar, lei que van a seguir subiendo de precio. A por cierto DDR4 quisiste decir.
« Respuesta #11 : mayo 26, 2017, 11:17:19 am »
LOL
me di 16 gigs de gskill ripjaws, la asrock fatal1ty x370 k4, otro disco duro (tendria 6 teras en total) , pendejaditas miscelaneas y un Ryzen R7 1700
« Respuesta #12 : mayo 26, 2017, 11:43:58 am »
LOL
Juela de un solo a los 8 nucleos, buena elección pensando a futuro, a ver hasta donde llega con OC ese micro.
« Respuesta #13 : mayo 26, 2017, 12:09:01 pm »
pues... viendo los resultados... tripeo que entre 3.8 en el peor de los casos y 4.0 en la mejor situacion.
Desconectado Big Boo
« Respuesta #14 : mayo 26, 2017, 08:12:05 pm »
Estas con todo man , con respecto a lo de la otra ves ya vi que no solo yo desconosco del tema sino que hasta ventas como KPC llame y me dijeron que el cooler CNPS5X PERFORMA no seria compatible para mi Rysen 1600X.
Y pues no es asi si el cooler ocupa el mismo bracket de la motherboard es compatible no importa que en su manual o especificaciones solo diga para AM3+ y pues al fin estoy con uno que aguanta mas que el stock AMD FX - 8350.
Ya voy a probar un para de juegos a ver si levanta 4K .....
En SVC desde el 2006 .
